A slow boot is one of the most common frustrations with Windows 11. You press the power button, grab coffee, and still wait. Often, the culprit is a long list of programs that launch automatically when your PC starts. Each one adds precious seconds to your boot time, and you might not even use half of them.
Windows does let you manage startup items through Task Manager, but it only shows basic entries and provides little context. Wise Care 365 gives you a cleaner view with more detail. You can see each program's impact on boot time, disable items in bulk, and even check your boot history. Here's how to do it.
Steps to Manage Startup Programs Using Wise Care 365
Step 1. Open Wise Care 365
Launch Wise Care 365 on your PC. If you don't have it yet, download Wise Care 365 from the official site. The setup takes about a minute.
Once it opens, you'll see the main dashboard with several modules: System Tuneup, System Cleaner, Privacy Protector, and more.
Step 2. Go to the Startup Manager
Click the System Tuneup tab at the top. On the left panel, you'll see several options. Click Startup Manager. This screen lists every program set to launch at boot, along with its status and impact rating.
You'll also see your current boot time at the top of the list. That's helpful for tracking how your changes affect boot speed.
Step 3. Disable Unnecessary Startup Items
Go through the list. Look for apps you rarely use, like old updaters, chat clients, download managers, or utilities that came bundled with hardware. Click the toggle next to each item you want to disable. Wise Care 365 will instantly apply the changes. No reboot is required, though you'll notice the difference only after a restart.
You can click this switch again to re-enable any items that may have been disabled by mistake.
Be careful with antivirus software and system drivers. Disabling those might affect security or hardware functionality. If you're not sure about an item, leave it enabled.
Wise Care 365 allows you to manage not only startup items but also scheduled tasks and services that run automatically at system startup. Simply switch to the "Tasks" or "Services" tab and click the toggle next to an item to disable it.
Managing startup programs is one of the fastest ways to speed up your Windows boot time. With Wise Care 365, you get a clear overview and one-click control over every startup entry. Check back after a few restarts to see your new boot time, and repeat the process if new programs sneak in. That's it, a faster boot with just a few clicks.
