There are many reasons why your computer could be running slowly, as you install more programs and devices on your computer; the start-up process begins to slow down. Here are some ways to fix this problem. Please follow the steps below to learn how to fix your slow computer. Let’s start!
6 Factors That Can Make Your Computer Run Faster
1. Reboot the system
Do you often try to turn it off and on again and again? While it might seem unlikely that a reboot will fix your PC computer, it can actually solve some slowdown issues. So rebooting isn’t the catch-all some techs might think it is, but it is worth having a try.
2. Check your hard drive’s health
A failing hard drive can significantly slow down your computer speed. So it is a good idea to keep on top of your hard drive’s health.
A fragmented hard drive will slow down your computer and affect the speed at which programs load and write to the hard drive. Defragmenting your hard drive on a regular basis will ensure that your programs are loading as fast as possible. Defragmentation happens automatically on most newer versions of windows, but it is important to check in regularly.
3. Clean up your startup sequence
If you add more and more programs to your computer, and some of them will add to your startup sequence. But so many programs will have a negative effect on your computer’s speed. So it is necessary to remove these unused programs from your computer’s startup sequence. Wise Care 365 can help you manage your startup menu. And it is totally free.
4. Clean up hard drive
If you have less and less space on your hard drive, it could be made your computer performance slow. Normally you’d better keep at least 25% of your hard drive free. Wise Care 365 is a powerful hard drive cleaning program by analyzing your computer and cleaning up useless files and registry entries.
5. Add Memory
Adding more RAM is another way to fix slow computer. If you are not comfortable opening up your PC and adding components, you will have to take it to a tech and have them fix it. Computer can be fragile devices, and it would be a tragedy to try to fix PC slow down.
6. Vacuum out the dust from your computer
Dust can clog airflow, which is vital to keeping your system temperature down and if it overheats, its performance will slow. Use a vacuum on a low setting to clean out the insides, but ensure the PC has been off at least 30-minutes and it is disconnected from the mains.
How about trying to use Wise Care 365 to fix your slow computer? If you have any questions about this article, please contact us by leaving a message.
