Home > Think Tank > What is the difference between 32-bit and 64-bit versions of Windows?
Aug 1, 2016
1. What is the difference between 32-bit and 64-bit versions of Windows?
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system.
2. How can I tell if my computer is running a 32-bit or a 64-bit version of Windows?
To find out if your computer is running a 32-bit or 64-bit version of Windows in Windows 7 or Windows Vista, do the following:
① Open System by clicking the Start button, right-clicking Computer, and then clicking Properties.
② Under System, you can view the system type.
3. Which version of Windows should I install: the 32-bit version or the 64-bit version?
To install a 64-bit version of Windows, you need a CPU that's capable of running a 64-bit version of Windows. The benefits of using a 64-bit operating system are most apparent when you have a large amount of random access memory (RAM) installed on your computer, typically 4 GB of RAM or more. In such cases, because a 64-bit operating system can handle large amounts of memory more efficiently than a 32-bit operating system, a 64-bit system can be more responsive when running several programs at the same time and switching between them frequently.
How to Repair a Disk PartitionHow to Access Advanced Startup (WinRE) on Windows 11How to Disable Hyper-V in Windows 11
