Home > Think Tank > How to Enable Super Drag and Drop Feature in Edge
May 6, 2024
What is Super Drag and Drop
Usually, if you want to open a link in a new tab you can right-click and select the option, or click your middle mouse button on the link. Now you do not need to click here and there to visit a website. The Super Drop and Drag feature of Microsoft Edge supports clicking the link and dragging it (just a little way, in any direction), then dropping it, at which point the link will appear in a new tab automatically.
In addition to a link, you can also select any text or picture on a web page, and then drag it before letting go, Edge will open relevant info in a new tab immediately. This feature could be quite handy when you want to open links and web pages quickly, especially when you’re a touchscreen user.
How to enable the Super Drag and Drop feature
Although the Super Drag and Drop is an excellent timesaver to use, it is not directly visible. You need to go into the browser settings to enable it.
Step 1. Open the Experiments page of Edge
First of all, you need to enter the Experiments page of Microsoft Edge, containing a list of experimental features not yet available in the stable build of Microsoft Edge. Copy the following address to paste in the address bar, then press the Enter key.
edge://flags
Step 2. Enable the Super Drag and Drop from the Experiments page
Type the Super Drag and Drop in the Search flag box to search. Then extend the drop-down button on the right and select Enabled under the Available tab. Once it is enabled, Edge will ask you to restart the browser, just click the Restart button in the lower right corner to go on.
Step 3. Find the Super Drag and Drop feature from Settings
After enabling the Super Drag and Drop feature from Experiments, you need to enable it again from Edge Settings. Click the three dots in the upper right corner, then select Settings> Appearance. Scroll down to navigate the Super Drag and Drop field in the right pane. Finally, turn it on.
Step 4. Configure the Super Drag and Drop
After turning on the Super Drag and Drop feature, you can adjust its settings by clicking the Configure Super Drag and Drop item. In there, you can change the new tab open mode and the search mode for text.
Now, you are ready to use it.
Disabling the Super Drag and Drop feature could be very simple. Just select the Default option in the Experiments page that we mentioned in step 2, then click the Restart button to finish.
Conclusion:
The Super Drag and Drop feature in the Edge browser can be quite convenient when you want to open links and web pages quickly. It is especially useful if you're using a touchscreen device, and can be customized according to your preferences.
How to Enable the New Start Menu on Windows 11How to Stop Microsoft Teams from Opening AutomaticallyHow to Disable Search Highlights in Windows 11
